adding side stokes to mask (not to the entire rectangle)
christine chao
on Sep 27, 2013 at 7:02:54 pm
I know how to add stroke to mask but is there a way to only add stroke to two sides of the mask instead of the whole rectangle? Thanks.
mathew fuller
Re: adding side stokes to mask (not to the entire rectangle)
on Sep 27, 2013 at 8:48:54 pm
Using 3d stroke plugin or generate stroke too i believe you can set a star end and percentage of stroke as well as positioning the offset.
My Work:
http://www.morecompletefx.com
christine chao
on Sep 27, 2013 at 9:05:21 pm
I tried what you suggested but can only have one border on the side instead of both left and right border... is there any other way?
mathew fuller
on Sep 27, 2013 at 11:59:48 pm
Split your mask in half and use one instance of the stroke effect for each half.
My Work:
