A halo effect in AE
Jerald Santhosh
A halo effect in AE
on Jul 13, 2013 at 12:13:57 pm
I want to be able to make a rotating halo(Saint, angel ring on head) in AE. I had some ideas, such as to make a shape layer of a circle and pre-compose it, made it 3d, rotate it in x axis and moved the duplicates on y axis to create depth and rotate it do I make it appear as though they are rotating on top of the head? Is there any easier way to achieve it?
William Scholik
Re: A halo effect in AE
on Jul 16, 2013 at 1:28:56 pm
You could try using 3d stroke to make the halo. This would allow you to have a 3d ring with depth. As far as rotation you could put a slight bend in the halo and this would allow you to see the rotation along the same plane as the halo. I'm sure that there are many other ways to do this as well.
“We cannot solve our problems with the same thinking we used when we created them.”
― Albert Einstein
Robert Spratt
on Mar 31, 2014 at 10:58:02 pm
Hi Jerald
I am looking for a halo effect and I saw your post. Did you ever manage to sort it? I would love any help you can offer. Many thanks for listening.
© 2018 All Rights Reserved
