Trouble with Motion Tracking and Replacing a Screen as it moves out of frame.
Tim Parry
on Apr 26, 2013 at 7:03:27 pm
Hello.
I am very new to AE, and have taken on a project with my gaming community.
I have a short clip of the problem I'm having uploaded to youtube, linked below.
This was done using a Perspective Corner Pin motion track, but as you can see, the track fails towards the end as the "screen" moves out of frame and the Green Blocks move into main focus.
I believe I need to manually place the track points as the "screen" moves out of frame, but upon attempting this, I realized I did not know of a way to maintain the correct perspective on the overlayed video as it moved out of frame, as I had no point of reference to match the track points up to.
Any help with this problem would be so greatly appreciated.
Thank you in advance,
Tim.
*I had originally posted this in the incorrect section of the forums, so I deleted that post and have reposted here instead. I hope this is okay*
Tim Parry
Re: Trouble with Motion Tracking and Replacing a Screen as it moves out of frame.
on May 3, 2013 at 2:24:26 pm
Solved the problem myself. Removed the video I embedded.
