29.75 fps - surprising popular HD format? Anyone use this?
Ann Clark
on Oct 15, 2012 at 6:05:39 pm
Hi all,
Extreme Reach came out with a survey of HD trends: their 2012 Q2 Broadcaster Supplement.
They describe two formats as having 29.75 fps (not 29.97 fps). I've seen lots of specs from networks, but never that frame rate. Maybe Extreme Reach is incorrect...?
HD continues to be a vexing issue for producers, with not only SD vs. HD to choose from, but further, which HD, how to create text/visuals/output for SD compatibility, and the relatively higher delivery cost of HD.
Anyone come across the 29.75 frame rate? Is there a standard Compressor format that works well for this?
Your thoughts...
To save you having to dig up the report, here's their "Top 5 HD formats" for broadcast and cable outlets. They say this is the top 5, but indicated there are hundreds of format permutations requested by networks. (So much for the HD transition ushering in new standards.)
QuickTime H.264 codec, 1920 x 1080i, 29.75 fps, 48kHz -2ch 31%
QuickTime H.264 codec, 1920 x 1080i, 29.75 fps, 48kHz -2ch - Map 7&8 to 1&2 30%
QuickTime 6 - HD for Final Cut Pro - 1920 x 1080 - 16:9 - 8 Ch Audio 25%
QuickTime H.264 codec, 1280 x 720, 59.94 fps, 48kHz -2ch 7%
MPEG-2 HD, HP@HL, 1920 x 1080, 40 Mbps, 29.97 fps- 2ch 7%
MacPro 2 x 2.8 GHz Quad-Core Intel Xeon 14GB memory - OSX10.6.8 FCP7
Dave LaRonde
Re: 29.75 fps - surprising popular HD format? Anyone use this?
on Oct 17, 2012 at 11:02:42 pm
Ma'am, I have never, EVER heard of a frame rate like 29.75. I have no idea how it would fare in NTSC-frame rate HD broadcasting which is either 29.97 at 1080 or 59.94 at 720.
Something smells very, very fishy if you ask me.....
Dave LaRonde
Former Sr. Promotion Producer
Ann Clark
on Oct 17, 2012 at 11:39:11 pm
Heh, heh...
Dave, that was my reaction, as well.
This data came from Extreme Reach, which I've had my doubts about as an objective source of information on broadcast matters.
Thanks for your reaffirmation of sanity.
