How do I achieve this effect?
Joni Els
on Aug 24, 2012 at 4:29:23 pm
I'm not to sure what it's called but I'm hoping to use this effect on some of my footage - can anyone help me oput please?
It's that colour flare/flash as seen at 0:04
http://vimeo.com/groups/streets/videos/34671998
Thank you!
michael zoppo
Re: How do I achieve this effect?
on Aug 27, 2012 at 2:53:59 pm
This is an extremely common TRENDY effect, so much so that plug ins have been developed to emulate the effect. It's just the process of splitting the color channels of your image/video source and then displacing them on the x axis. Videocopilot makes a good plugin that can emulate this as well as other twitchy looks https://www.videocopilot.net/products/twitch/features/ . But if you just make two layers of your video footage one with a green color channel and the other with a blue and then animate their positions on the x axis SLIGHTLY , you should only need them to separate or move away from each other by about 50-200px or so. Make it jumpy and quick and maybe add in a glow and you'll have the same effect. It's ALL ABOUT experimentation.
hope this helps
Luke Tyrrell
on Jan 17, 2013 at 9:13:38 pm
Twitch RGB SPLIT
