Placing a video into a moving and rotating object
Joel Espino
on Aug 14, 2012 at 2:31:41 am
here is a link to what I am trying to nest my video in:
http://reels.creativecow.net/film/moving-and-rotating-frame
The white frame will be replaced with video on this project i am working on. The problem is the if I use parallel tracking mode that white square becomes small, if I use transform tracking mode then the white target offsets. (even though i can select all key frames in the position of that target and line them up it, it will only rotate.
Please help.
Andrey Sibiryakov
Re: Placing a video into a moving and rotating object
on Aug 16, 2012 at 8:49:14 am
I can point you to some useful tuts only.
http://ae.tutsplus.com/articles/roundup/26-tracking-and-3d-matchmoving-plus...
Hope, some will help.
