Applying an effect to a roto brushed area
Martin Robbins
on May 17, 2012 at 11:52:26 am
I have used the roto brush to select a section of my video which is 10 seconds long. I just want to reduce the brightness on this particular area, and leave the rest of the video as it is. The process I have currently gone through is:
Roto brush
Duplicate
Remove Roto brush on bottom layer
Select top layer
Then add filter.
However when I'm doing this, in the layer window, I can only see the roto-brushed area, which appears to be changing. but it's applying the filter to all. In the footage window I can see the whole shot, but no changes are being applied.
Any suggestions as to what I'm doing wrong?
