Square Visualizer
<< PREVIOUS   •   FAQ   •   VIEW ALL   •   PRINT
Marek Ištok
Square Visualizer
on May 17, 2014 at 10:47:05 am
Is there a way how to make Audio Spectrum lines, which are defaultly round-ish, into totaly flat square ones?
Like Monstercat has in his videos?
Marek Ištok
Re: Square Visualizer
on May 19, 2014 at 5:21:07 pm
Does nobody know this? :D
I knew it was hard to do, but there has to be a way.
Michael Szalapski
on May 20, 2014 at 1:54:49 pm
It's not hard to do, but it is time-consuming. As far as I know, you can't do it with the built-in effects. You would need to use Sound Keys to create keyframes for solid layers or shape layers. (Or mess around a LOT in Audition to create a separate sound file at different frequencies for each bar.)
- The Great Szalam
<< PREVIOUS   •   VIEW ALL   •   PRINT
