Create a Mask on a text layer.. where the text moves, but the mask stays still?
<< PREVIOUS   •   FAQ   •   VIEW ALL   •   PRINT
Paul Boone
on May 23, 2014 at 7:43:27 pm
Ok, so I want the text "Purell" to appear like its sliding out, from behind the Purell bottle, and I've created a rectangle mask that I want the text to start behind, and then slide to the right revealing the letters.
Anyways, I want the mask to stay still, and the letters revealed when they slide right. My mask moves with my text.. and I don't know how to get around that.. thanks
George Goodman
Re: Create a Mask on a text layer.. where the text moves, but the mask stays still?
on May 23, 2014 at 7:55:07 pm
Don't use a mask, instead use a track matte.
Draw the shape of your track matte with the shape tool. Place the text underneath that shape (both in the layer stack and in the composition). Then in the text tool, select "alpha matte" under trk matte. Now, the text will only appear while it is inside that shape. It will be gone as soon as it leaves the track matte - so just animate the text normally.
"|_ (°_0) _|"
Sincerely,
George
http://www.vimeo.com/georgegoodman
http://www.linkedin.com/in/georgefranklingoodman
Stephen Smith
on May 24, 2014 at 3:37:14 pm
Or you can always animate the text the way you want. Then PreComp it and choose Move All Attributes Into The New Composition. This will keep your position change with your layer. Then add a mask to the PreComp which doesn't have any position changes and you are done. Best of luck.
Stephen Smith
Utah Video Productions
Check out my Vimeo page
<< PREVIOUS   •   VIEW ALL   •   PRINT
