Make a Particular Light Streak go Behind someone?
Tim Fisher
on Mar 5, 2012 at 5:26:38 am
So basically I want to record myself playing piano, and at certain parts I want to implement Trapcode Particular. I am going to make a streak of light and I sort of want it to circle around me. I have seen it done before and have pondered some possibilities, but ultimately do not know how to approach this.
Stephen Smith
Re: Make a Particular Light Streak go Behind someone?
on Mar 6, 2012 at 8:29:47 pm
Here are two approaches:
1-Shoot yourself playing the piano and duplicate the clip. rotoscope yourselef so the top layer is just you and the bottom is the whole clip. Then you can make the light streak go behind you.
2-Shoot yourself in front of a green screen and key out the green, then add the background. Then you can make the light streak go behind you.
Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Vimeo page
