light from rear
James Hughes
light from rear
on Feb 27, 2012 at 7:43:49 am
if i add a light to a comp it will light up the 3D layer that is stacked underneath it.
When I move the light position to be behind the 3D layer, why doesn't it backlight that layer creating a halo like it would in real life?
cheers,
Dave LaRonde
Re: light from rear
on Feb 29, 2012 at 9:39:14 pm
Two reasons:
1) AE cameras can't see AE lights, even if they shine straight into the camera. It sees the light that falls on 3D layers, not the light itself.
2) Backlighting is created by light falling on 3D surfaces: shoulders, head, etc. If your 3D layer has no z-depth, the light has nothing it can fall on.
Dave LaRonde
Sr. Promotion Producer
Andrew Somers
Re: light from rear
on Mar 12, 2012 at 7:27:31 am
Halo as in reacting with the atmosphere?
There is no "atmosphere" in AE - though you might be interested in the plug in LUX from Trapcode, which might help you achieve the effect I think you are looking for. It makes AE's comp light visible.
