split a video
aldo montesano
split a video
on Dec 7, 2011 at 1:44:42 pm
Hi there...i'm new on the forum...i will like to know if it ios possible to do this thing:
i got a footage in which i have 3 actors, i will like to split the image in 3 diferents parts( each part for each actor) and work them separately( i need to change speed)...
it's that possible??
i got after effect cs5 and cs5.5
Michael Szalapski
Re: split a video
on Dec 7, 2011 at 4:11:27 pm
There's actually an After Effects forum here on the COW that's a little more active for when you have questions in the future.
In any case, you're going to need to mask off the various parts and play with the timing of each one.
It would be best if the three characters are in seperate videos rather than all together in one clip in case they cross over each other's areas.
- The Great Szalam
aldo montesano
Re: split a video
on Dec 8, 2011 at 1:00:19 am
Thanks Michel....very helpful...i also just discover the timewarp effect that it's exactly what i need...anyway when I'll shoot i will keep in mind your advise and shoot the both way:
with the 3 actors in different clips and with the 3 actors in the same clip...
thanks again
© 2018 All Rights Reserved
