Expressions: Change a value of another layer
Tim Och
on Jun 2, 2014 at 9:36:29 pm
Hello,
this might be a really stupid question for you, but i`m just getting started with expressions and after 2 hours of pointless searching for a solution i don`t really know what to do.
I want to manipulate the opacity of several layers from one single null-layer, now to start i tried manipulating the value of a single layer ("layer 1",a plain red layer).
After trying several different functions and methods with:
thisComp.layer("layer 1").transform.opacity
i was stuck and now i need your help. How can i change the Opacity of "layer 1" with a expression from "null 1"
Best Regards
Tim
Todd Kopriva
Re: Expressions: Change a value of another layer
on Jun 2, 2014 at 11:08:13 pm
Use property links:
http://blogs.adobe.com/aftereffects/2013/09/after-effects-cc-12-1-whats-new...
After Effects team blog
Tim Och
on Jun 3, 2014 at 12:28:22 pm
thanks for your answer. What you wrote makes sense if i only want to control one layer with another layer, but i want to control 10 layer opacitys from one layer. Is this possible in any way ?
Best Regards
Tim
Michael Szalapski
on Jun 3, 2014 at 1:45:10 pm
You can copy and paste the created expression to as many other layers as you want.
- The Great Szalam
Todd Kopriva
on Jun 3, 2014 at 4:00:36 pm
Yes. That's what property links were designed for. Try it.
