Liquid Motion
Jason Stickney
Liquid Motion
on Jan 5, 2011 at 7:12:52 pm
I am experimenting with a promotional video and want to know if/how I can have the effect of champagne pouring onto text. Is this possible at all? Any and all feedback would be greatly appreciated.
Walter Soyka
Re: Liquid Motion
on Jan 11, 2011 at 2:57:42 am
[Jason Stickney] "I am experimenting with a promotional video and want to know if/how I can have the effect of champagne pouring onto text. Is this possible at all?"
Sure -- anything is possible in visual effects with enough time and budget!
What you are looking to do is called a fluid simulation, and it must be done in a 3D application. RealFlow and FumeFX are a couple leaders in the category. Expect steep learning curves and steep price tags.
Depending on the look you're going for, you might be able to do your effect practically by actually pouring champagne.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Cory Petkovsek
Re: Liquid Motion
on Jan 12, 2011 at 10:03:38 am
Since you are just experimenting, and not wanting to blow $4k on realflow, you can download blender 3d and experiment with your effect in it's fluid simulator (and some web tutorials). If that is too complex for you, so will any other 3D render based solution. If not, then you're mostly there, now you just need a proper material, lighting and rendering, then compositing the 3D animation with your 2D animation and live video as needed.
Cory
Cory Petkovsek
Corporate Video
Mark Suszko
Re: Liquid Motion
on Jan 19, 2011 at 10:35:10 pm
I think on the cheaper side and maybe simpler, Digital Juice probably has some paint throws and liquid pours and splashes in their compositor's toolkit collections that you could composite in and make work as well.
