Motion Renders black in FCP
Frank Mojica
on Nov 7, 2010 at 5:35:38 am
I'm having problem with Motion and FCP 6 working together. When I bring in an .motn and pace it in the timeline then place the head over the clip it shows that it is there and looks right but of course needs to be rendered. I then render it and after render it is just a black screen. I am running FCP 6 and motion 3 on a MacBook 2GHz Duo, with 4 GB Ram. Any help would be much appreciated. Thanks
Stephen Smith
Re: Motion Renders black in FCP
on Nov 8, 2010 at 3:49:02 pm
Frank, I've never seen this before so my advice may be of no help. Make sure your render settings in FCP are set to Normal or Best. Make sure the Resolution is set to 100% and the codec it set to "Same as Sequence Codec." Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Frank Mojica
on Nov 11, 2010 at 6:42:03 am
Thanks for the reply Steve. Everything is set properly. Wondering if my machine is just not strong enough?
