Running motion 4 template
kevin jackson
on Sep 3, 2010 at 3:55:34 pm
I havev one of the motion templates from motionvfx and it runs really slow. Even when I put the render setting to the lowest and also lights and shadows off. Is there any way to make it run faster and smoother setting wise?
k. jackson
g point productions
Stephen Smith
Re: Running motion 4 template
on Sep 13, 2010 at 7:19:19 pm
I've never used the template but I imagine it is very complicated. Because Motion works in real time the more complex the template gets the slower it goes. Sorry, I'm sure this is not the answer you want.
If you are outputting through the Kona card to view on an external monitor that can effect realtime playback. There are other things you can do to improve playback performance like turning off thumbnails in the Layers tab and soloing layers.
Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
neha Gupta
on Aug 26, 2011 at 9:32:42 pm
Hi Kevin,
Were you able to solve this issue? I am having the same problem. How did you resolve? Please
© 2018 All Rights Reserved
