Plugins for beginer
gregory sawik
Plugins for beginer
on May 13, 2016 at 3:44:15 pm
Hi there i would like to buy adobe after effects and get some grip on recomended plugins. What plugins do i look ? Well plugins for making better qualithy videos taken from phone devices...
Also looking for some creativy play with letters and figures, please give me advice, thanks.
Daniel Waldron
Re: Plugins for beginer
on May 13, 2016 at 4:55:45 pm
You can't use plugins in After Effects to just drag and drop and make your video better. You need to understand the basics of After Effects and then have a goal of what you want to create. If you need a plugin to achieve that, then purchase it and learn how to utilize it. Often times though, you can achieve what you need with the native tools inside of After Effects.
Kalle Kannisto
on May 13, 2016 at 7:14:13 pm
I mostly use the built-in tools for this type of thing. Temporal noise reduction, stabilization, color correction, etc. All of them require manually adjusting the settings for best results.
gregory sawik
on May 14, 2016 at 7:52:55 am
Ok, thanks for quick reply...one more thing, if you can recomended for me pc, which parts should i go with my project - getting better quality of videos recorded on smartphones and adding dynamics letters, animation into videos?
Which mean i need powerfull pc for both, rendering and affects, but more for rendering...my budget is 1,500 $
Tyler Wilson
on May 16, 2016 at 1:10:05 pm
$1500 is a good start but what exactly do you need? Purely desktop? Or also monitor, mouse, keyboard, etc? And exact uses also matter. Mostly for AE and rendering? You can use logicalincrements.com for a general overview of how you should spend it.
gregory sawik
on May 16, 2016 at 2:45:25 pm
hi, so i need mostly for rendering, which, put together movies, tuned up to high qualithy, make some nice video with animation effects...I beleive that i dont need graphic card yet, but in the future yes...
my budget is 1500 +/- only parts no os
Intel CPU i7-6700K 4.0GHz, 8M, LGA1151, VGA
Gigabyte GA-Z170-Gaming K3 -EU S1151 4DDR4 USB3.1
HyperX DDR4 Fury Black 16GB/2133 (2*8GB) CL14
Intel 540s 240GB SATA3 560/480MB/s 7mm
Seagate Barracuda ST2000DM001 2TB 3.5'' SATAIII 64MB 7200rpm
LG Electronics DVD-RW WEW SATA
SilentiumPC Gladius X60 Pure Black USB3.0 ATX/SSD ready/3x120mm
Be quiet! Pure Power L8 600W 80+ Bronze BN224
SilentiumPC Chłodzenie CPU - Grandis XE1236 - 2x120mm
IIYAMA 21.5'' XU2290HS IPS
I would like to add in the future more ram and some graphic card...
Please let me know is this suitable one for my work ....
