Shape layer single line
Hamid Rohi-Bilverdy
on May 8, 2016 at 7:33:44 pm
Hi
With the pen tool i create a vertical straight line(shape layer). I use the pan behind tool to move the anchor point to the bottom of the straight line.
I then add a repeater. Set position value from 100 to 0 so the 3 default lines merges to one line. Then when rotating the extra lines is rotating from the middle instead of the bottom where i moved the anchor point to.??
Kalle Kannisto
Re: Shape layer single line
on May 9, 2016 at 8:37:12 am
You have to move the Transform anchor point rather than the shape anchor point.
