Batch Change Resolution - possible? necessary?
Klaus Boehmer
on May 8, 2016 at 3:12:21 pm
I have a main composition which consists of two or three dozen "sub-compositions". By default, they are all set to "quarter resolution". Now I have two questions:
In order to achieve the best resolution, is it necessary to all change all resolutions (meaning all "sub-compositions" resolutions, too)? Or is it sufficient to simply alter the main composition?
If it is indeed necessary to change all resolutions, is there is a script to batch-job the task? All scripts I have found so far allow me to alter various other composition settings but not the resolutions.
thanks
Kalle Kannisto
Re: Batch Change Resolution - possible? necessary?
on May 9, 2016 at 12:54:22 pm
I gather that by "resolution" you are referring to pixel dimensions of the comp.
This script claims to do it. Personally I couldn't get it to work in AE CC 2014.
http://aescripts.com/rd-compsetter
