How do you make abstract molecular designs?
Asshwin Mugundharajah
on May 6, 2016 at 4:23:59 pm
Not sure if this is the correct place to be posting this as i am kinda new. I want to make something similar to this https://www.shutterstock.com/video/clip-9465020-stock-footage-abstract-mole... and have it looped as well just like in the video. Are there any plug ins or presets that helps me achieve this effect or will i have to use another type of software such as a 3d animation software.
Cheers.
Michael Szalapski
Re: How do you make abstract molecular designs?
on May 6, 2016 at 8:19:55 pm
You could create this in Cinema 4D or something like that, but you can also make something similar in AE using a third-party plugin like Form or Plexus.
- The Great Szalam
Kalle Kannisto
on May 7, 2016 at 1:45:22 pm
That specific look is Plexus, but like Michael says, it can be done with other plug-ins as well.
John Cuevas
on May 7, 2016 at 2:26:08 pm
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
John Cuevas
on May 7, 2016 at 2:32:39 pm
Here's a tutorial that links uses a script to connect all the points. Script part is at the 2nd half of the tutorial.
ThinkCK
