Adobe After Effects CC 2015
johnny fan
on May 4, 2016 at 2:19:34 am
Hi, I was searching for help when I ran into a problem with after effects and I decided to create an account with creativecow. So my first post of the day with this website is that. I'm trying to follow this tutorial off youtube :
. I follow his instructions very closely because I am fed up after a multiple of tries. I also bought a new laptop for this type of specific work. When I create a new solid layer with fractal noise effect and add feathering into it. The instruction on youtube then proceeds to adjust the brightness of that layer. His fractal noise layer begins fades out until its no longer there. For my situation. I did the same thing but my mask which has the feathering tool on leaves a white line. Even though I decrease the brightness of the layer.
The tutorial I am following.
The white line that I have before I decrease the brightness of the layer.
https://drive.google.com/file/d/0Bx1kyyH_heT0NW9Rb3hGdC04RDZrYmJFZmszU0hQYT...
I'll be so grateful if someone can help me fix this problem that I came across.
Kalle Kannisto
Re: Adobe After Effects CC 2015
on May 4, 2016 at 8:53:13 am
My guess: make the solid black.
johnny fan
on May 4, 2016 at 11:13:37 pm
Thank you for the quick response. You are definitely right. I left my solid layer color white when it should had been black.
