Could not allocate sound memory issue.
Ruud de Ruijter
on Apr 10, 2016 at 11:02:40 am
So when I want to play my composition in adobe after effects, using that play button on the right side of the screen it says this error: could not allocate sound memory. When I press the period key on my numeric keyboard, then I just hear the sound. I made a sound visualizer, if that helps. When I import my adobe after effects project into premiere pro and if I play it then it just repeats a bit of a music file over again and again. I hope that someone can help me with this issue.
Dave LaRonde
Re: Could not allocate sound memory issue.
on Apr 10, 2016 at 5:51:50 pm
I recommend simply rendering the file out of AE, importing it into PP, and seeing if things are good.
From the scant information you provided, it is difficult to recommend anything else.
Dave LaRonde
Promotion Producer
Ruud de Ruijter
on Apr 11, 2016 at 1:29:16 pm
Okay, but I am not sure if there will come sound if I render it in after effects. What I do in premiere pro is just importing the adobe after effects project and then I can select what I want to import and then I select comp1, which is the visualiser+music.
Dave LaRonde
on Apr 12, 2016 at 7:03:07 pm
It doesn't matter. Import the AE animation, import the audio, and sync them up in PP. Very easy to do.
Dave LaRonde
Promotion Producer
Ruud de Ruijter
on Apr 12, 2016 at 7:04:12 pm
Okay I'll do that.
