Minimum line width
Jerry Smith
Minimum line width
on Mar 31, 2016 at 2:33:07 pm
For a 1920x1080 composition that will be rendered in a bunch of different ways, what is the minimum safe size for a line? I read somewhere that 3 pixels was a good rule of thumb.
John Cuevas
Re: Minimum line width
on Mar 31, 2016 at 2:57:55 pm
If it's progressive, you should be able to do a pixel width of 1. Unless I have good reason, I stick to 1.5 to 2 at the low end, depending on the project. I would just make a couple of quick test animations(create lines of 1,2,3, & 4 pixels wide), compress to all your deliverable formats and determine my min based on the most compressed file.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
