Gold "oscar" edges
Grzegorz Kopowski
Gold "oscar" edges
on Mar 23, 2016 at 7:37:21 pm
Hello, I am trying to make gold edges like this:
For now I have:
I have added bevel alpha but it still looks bad. Is there anything else I could do to achive edges like in original image?
John Cuevas
Re: Gold "oscar" edges
on Mar 24, 2016 at 1:06:58 pm
Which version of AE. If it's CS6 or newer, I would create a shape layer, make it 3D, then change the render engine to 3D(cntl+k then advanced). Then start adding some lights, and a material to use as a reflection/environment map. If you have C4D light, you would get even better results there.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Grzegorz Kopowski
on Mar 29, 2016 at 8:10:57 am
Thanks John for great tips! I have AE CC 2015.
