Animating Graphic Images in a Circle
Chip Hess
on Mar 21, 2016 at 4:24:12 pm
I have some PNG images I need to arrange around a circle, then rotate the circle of objects.
I have been creating a circle mask/path using the ellipse tool. But getting the objects to snap to that circular path is the rub.
The tutorials I have found online seem to all use the pen tool to draw a path freeform. I need a perfect circle.
What is the best/easiest way to do this, thanks!
Dave LaRonde
Re: Animating Graphic Images in a Circle
on Mar 23, 2016 at 2:58:57 am
I answered this same question just yesterday someplace else. I forget where.
Dave LaRonde
Promotion Producer
John Cuevas
on Mar 23, 2016 at 2:21:09 pm
Hold down shift for a perfect circle, add cntl after you start making your circle to have it anchor to where you started making your circle.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Chip Hess
on Mar 25, 2016 at 10:14:32 pm
Thanks.
So here is what I am seeing.
I draw the mask/path, perfect circle.
Copy mask path, paste it onto position
of the image I need to align.
When I do that, another path with handles
gets created, and the image follows THAT path.
I suppose I could live with that, but how to move
or resize that path with the handles?
Dave LaRonde
on Mar 25, 2016 at 10:41:48 pm
You start over from scratch: go back to the circle mask you made. Double-click on it. You now see the Bounding box. Holding down the Ctl-Shift keys (Cmd-Shift Mac), grab a corner and make the circle shrink & grow. You have to eyeball it.
Then you copy the altered mask path and paste it into the layer's position property.
Dave LaRonde
Promotion Producer
Chip Hess
on Mar 27, 2016 at 10:21:49 pm
Thanks so much guys, everything is working now :-)
Chip Hess
on Mar 31, 2016 at 1:52:33 pm
One more obvious question -
Other than eyeballing it, is there a more precise way
to align the objects around the circle, so they are
exactly spaced apart?
Dave LaRonde
on Mar 31, 2016 at 5:33:33 pm
Yeah, do the circle thing I outline in this thread:
https://forums.creativecow.net/thread/2/1071611
Dave LaRonde
Promotion Producer
Chip Hess
on Mar 31, 2016 at 6:35:27 pm
Dave, does the referenced null technique automatically space all images equally distant from each one's center? So they are distributed equally around the circle?
That wasn't my understanding - hence the question.
Thanks.
Dave LaRonde
on Mar 31, 2016 at 6:37:06 pm
No, but they'll all have the same distance from the null. Change one.... copy 'n paste. Done.
Dave LaRonde
Promotion Producer
