Automated multiple render of the same composition with different layers
David Slachta
on Mar 8, 2016 at 7:20:26 am
I have an image sequence of a car rotating on a turntable over 360 degrees and I need to change the car's color and output the modified sequence. My problem is that there are 9 colors of the car which I need to output. So what I'm doing right now is that I enable the "Silver" layer and render. Enable the "Black" layer and render. Enable the "Red" layer and render and so on until I have all 9 colors rendered. Every time the background changes or some adjustment curve changes I have manually re-render all of the 9 colors again.
Is it possible to write a script that would do exactly as I do manually?
1. Render the composition as a TIF sequence from frame 0-35 named as A
2. Enable layer 1
3. Render the composition as a TIF sequence from frame 0-35 named as B
4. Enable layer 2
5. Render the composition as a TIF sequence from frame 0-35 named as C
6. Enable layer 3
7. ...
8. ...
Could anybody help me how to write such a script if possible?
Thank you very much!
David
John Cuevas
Re: Automated multiple render of the same composition with different layers
on Mar 8, 2016 at 2:21:15 pm
This script might help. Render Layers
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
