Rendering takes ages
Marco Kohlmann
on Jan 10, 2016 at 8:35:58 pm
Hello guys,
i have the problem that whenever i try to render a music video that ain't longer than 5 minutes, it takes about 9-12 hours, i use low effects for the video and it still won't go any quicker for me.
My comp has 8gb ram, w7 with service pack 1, around 70gb free space.
Settings are:
Framerate: 29,97 for youtube, also tried 25 before.
I tried AVI without codecs, Quicktime with mp4(H264)+ AAC and Quicktime with Animation + AAC.
If you need more infos, tell me.
I hope someone can help me out there.^^
Tero Ahlfors
Re: Rendering takes ages
on Jan 10, 2016 at 8:51:38 pm
What's your processor? How many layers do you have? Do you have any 3D-layers/lights/motion blur/precomps? What do you mean by "low effects"? What format is the original footage in?
[Marco Kohlmann] "Framerate: 29,97 for youtube, also tried 25 before."
Do you know what you're doing?
Marco Kohlmann
on Jan 10, 2016 at 8:59:26 pm
AMD FX(tm) 8120 Eight core 3,1 ghz
I use 5 layers in total...
With low effects i meant that i dont use many effects in my video.
Format is 1920x1080 or did you mean something else?
I heard that are the best framerates for youtube videos.
Dave LaRonde
Re: ndering takes ages
on Jan 10, 2016 at 10:58:37 pm
Okay, that response demonstrates that you don't know what you're doing.
What's the frame rate of your video, and what's the frame rate you have to DELIVER?
Dave LaRonde
Promotion Producer
Marco Kohlmann
on Jan 10, 2016 at 11:12:45 pm
the framerate of my video is 25 too, how do i find out then what i should use/deliver?
Dave LaRonde
on Jan 10, 2016 at 11:45:22 pm
25.
Dave LaRonde
Promotion Producer
Marco Kohlmann
on Jan 11, 2016 at 10:46:37 am
Well like i already mentioned,i tested it with 25 too, didnt work.
Dave LaRonde
on Jan 11, 2016 at 2:50:45 pm
Well, I'll guess you're running. AE CC 2015. I recommend you use AE CC 2014 instead.
The newer version is no picnic for newcomers -- you need to be an AE expert or have a computer science degree to even get it running poorly.
Dave LaRonde
Promotion Producer
Marco Kohlmann
on Jan 11, 2016 at 5:38:27 pm
i'll try on CC 14 then, but would it change the result? i mean why would it work with same settings on CC 14 but not on CC 15?
Dave LaRonde
on Jan 11, 2016 at 5:45:48 pm
I could make a list, but I'd like to get home before bedtime tonight.
Dave LaRonde
Promotion Producer
Marco Kohlmann
on Jan 11, 2016 at 10:30:05 pm
no worrys, i have lots of time, i would really appreciate some tips^^
Dave LaRonde
on Jan 11, 2016 at 10:50:17 pm
Well, here are just two, and they're biggies:
Multiprocessing doesn't work.
No audio on rendered files unless they're Quicktime movies.
People also report a panoply of other woes, dependent on hardware and OS versions. Sometimes the application just does not launch. Sometimes it quits just by hitting a control adjustment.
This OUGHT to get sorted out. But I don't think it will be any time soon.
Dave LaRonde
Promotion Producer
Marco Kohlmann
on Jan 11, 2016 at 11:20:26 pm
i just tried something new and it kinda made it better, but still takes around 2,5h.
Only things that i changed are using the "region of interest" which shortened the screenpicture to 850x484 instead of the 1950x1080, also used quicktime + animation. Problem is, i don't wanna cut out more of the screen :D
Daniel Waldron
on Jan 11, 2016 at 3:45:21 pm
If your video is for YouTube, you should export at the original frame rate... What effects specifically did you use? Rendering time varies dramatically based on this. It may be perfectly normal for a 5 minute video to take this long on a computer with your specs.
