How can use Adobe Premier Transition on After Effects?
Vugar Ashrafov
on Jan 5, 2016 at 6:55:40 am
Hi.How can use Adobe Premier Transition on After Effects? without entering Premiere,just inside After effects. for example i have "Filmimpact transition pack". i want it use inside After effects. does it possible?
Dave LaRonde
Re: How can use Adobe Premier Transition on After Effects?
on Jan 5, 2016 at 3:35:22 pm
It is not possible. You must export video from Premiere containing the transition, then use the exported video in after effects.
If you don't want to do that, you can render the incoming and outgoing clips in AE, import them into Premiere and apply the transition. Don't forget to include trim handles.
Dave LaRonde
Promotion Producer
Vugar Ashrafov
on Jan 6, 2016 at 7:37:23 pm
Thank you very much!
