Stabilisation Issues in underwater footage
Giulia Grimaldi
on Dec 9, 2015 at 5:03:31 pm
I am new to AE and mocha.
I am trying to stabilise this clip (https://reels.creativecow.net/film/stabilizing) tracking in mocha and then exporting the info to AE CS5 for stabilisation.
I tracked the red sea squirt in the middle as an object to follow (using the default settings). I export the tracking data to the clipboard and then paste it to the clip in AE.
Here I tried different settings (selecting "anchor points" only, deselecting "position" and changing rotation to 'rotation * -1'
and Scale to '
x = 10000/scale[0]; y = 10000/scale[1]; [ x, y ];- and playing around with the scale factors, and different combinations of these changes).
However, the video still appears jerky.
Is it because the light motion throws off the blue anchor points in the tracking in mocha - I can see the blue lines "flip"?
What would a good object to track be in a video like this?
What settings should I use in mocha or AE to make the clip smooth and stable?
Ivan Myles
Re: Stabilisation Issues in underwater footage
on Dec 9, 2015 at 8:34:37 pm
Sorry, but the link in your post produces an error message: "This Video has been Deactivated."
Giulia Grimaldi
on Dec 10, 2015 at 12:03:06 am
Apologies. I re-uploaded it at this link: https://reels.creativecow.net/film/24295
Ivan Myles
on Dec 10, 2015 at 12:16:09 am
I use motion tracker in AE, so this advice might not translate to Mocha. Look for a tracking point in the center third of the frame where the lighting is relatively constant. I think the moving flashlight, moving camera, and lens/water distortion are causing problems. Also, it is normal (with AE motion tracker) to use several sequential tracking points to get through the length of a clip.
Giulia Grimaldi
on Dec 10, 2015 at 12:28:00 am
Thanks. I'll try. I had similar issues with a video without the flashlight. and it still jerks at one point. Perhaps sequential tracking will do the trick… Thanks.
Giulia Grimaldi
on Dec 10, 2015 at 10:18:57 am
:'( unfortunately didn't work. even changing tracking points gives a similar effect.
Dave LaRonde
on Dec 10, 2015 at 6:23:26 pm
How long is this clip in actuality? You may be able to stabilize it by using position keyframes.
It also would be helpful to know the footage's frame rate, and the comp's frame rate. There may be some issues with them.
Dave LaRonde
Promotion Producer
