Solar atmosphere tutorial. Need to make it blue color
Adushi adi
on Dec 1, 2015 at 11:05:31 am
Hi guys,
First of all let me get it out of the way right here. Im a beginner and really like after effects so much that i am eager to learn everything, and i mean everything.
Can across this awesome tutorial on YouTube and thought to myself lets try to make something like that.
I did all of the steps and it came out awesome to say the least.
Only i do not want the same outcome as the tutorial ... there is no personal touch there ... so i am looking to make it a little different with a blue very very nice blue color to the sun. Yes there are blue sun's they are called blue giants. :)
You can see the sun in this youtube video
The color in the tutorial is orange/yellow like the right color of the sun as it should be, but i am looking to change that to the color blue.
How can i go about in doing that?
Thank you for any help here! :)
John Cuevas
Re: Solar atmosphere tutorial. Need to make it blue color
on Dec 1, 2015 at 7:15:22 pm
It's right there in the tutorial at around 19:00 minutes. Instead of cranking up red/decreasing blue, you would do the opposite. Crank up the blue channel, decrease red.
Also, you could just add a hue saturation effect and rotate the hue until you turned it blue.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Adushi adi
on Dec 2, 2015 at 1:57:55 pm
Thank you so much, The hue saturation helped out a lot i got my design.
Daniel Waldron
on Dec 2, 2015 at 5:31:14 pm
Kramer also made a nice Vibrance plugin that should do the trick. I haven't used it much, but it supposedly will give you some better (aka more vibrant) results than hue/saturation.
John Cuevas
on Dec 2, 2015 at 6:02:27 pm
I've used it and should have mentioned it. It's a good little tool for quickly colorizing things. Thx for the reminder.
ThinkCK
