Importing Premiere Pro, Transparent Layers not blending
Ashley Smith
on Nov 7, 2015 at 6:26:16 pm
Hello Creative Professionals,
I brought a sequence into After Effects with a few Graphic Effects. One of which is a photoshop layer which was in Premiere and I added Red Giant Shine effect. It looks great in premiere.
When I bring into After Effects the effect seems to get cut off by the boarder of the Graphic Object's dimensions. So it's hard cut off that looks ridiculous. I hope I'm making sense. Any help would be appreciated. I have a very short turn around time.
Below Pictures for reference
Ash!
http://www.ashleysmithfilms.com
Dave LaRonde
Re: Importing Premiere Pro, Transparent Layers not blending
on Nov 8, 2015 at 3:30:10 am
Put the PSD into a nested comp, and make its dimensions much larger. Apply Shine to the nested comp.
An alternative: apply the Grow Bounds to the un-nested PSD. It may have to be the firsr effect in the stack; I forget.
Dave LaRonde
Promotion Producer
Ashley Smith
on Nov 8, 2015 at 4:17:49 pm
Hi Dave I'm giving it a go and not having much success.
I created a new comp, added the psd File, resized it using the transform tool, then brought that composition into the working composition and I had no success.
Once I add the photoshop layer to a nested composition, do I make the dimensions of the psd file much higher or the dimensions of the AE comp?
I tried to add Grow Bounds to the PSD clip as well and it didn't help.
Let me know your thoughts,
Dave LaRonde
on Nov 9, 2015 at 5:12:34 pm
Wrong way to do it.
Put your PSD in its own comp. Make this comp's horizontal & vertical dimensions much larger. An easy way is to open the comp settings, make sure the little chain-link icon is on, then just multiply one of the dimensions by... oh, four.
Put this comp into the main comp. Apply Shine. Happiness ensues.
Dave LaRonde
Promotion Producer
