Error Logs Default Path
Jozua Judah
on Aug 24, 2015 at 9:50:21 am
Hi
I would like to know if the error log which is created on render could be saved in a different location?
Regards
Jozua Judah
John Cuevas
Re: Error Logs Default Path
on Aug 24, 2015 at 3:12:32 pm
You could try searching through the AE preferences file, see if the path info is located there.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Jozua Judah
on Aug 25, 2015 at 6:35:57 am
I did check that but there was nothing there, even did a google search on the topic but it revealed nothing, so I thought I would ask on this forum. I am current using After Effects CC 2015.
Regards
Jozua
