Collapse Bounding Box?
Matt Clara
on Aug 5, 2015 at 2:51:13 pm
Using AE CC 2014. I have an imported illustrator file I'm working on with lots of parts that need to be moved about. Problem is, when I select a part, the bounding box around it is huge instead of being the size of the part. Is there anyway to collapse the bounding box down to just encompass the part it's associated with? In the image below, I have just the character's forearm selected, but the box is the full 1920x1080. What the hell???
Thanks for your time.
John Cuevas
Re: Collapse Bounding Box?
on Aug 5, 2015 at 3:20:00 pm
Not sure what you can do now, but when you import your illustrator document, import it as a composition so it comes in as layers(you will need to layer everything in AI). Then during the import you will need to select for "Footage Dimensions" > Layer Size.
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
© 2018 All Rights Reserved
