Colour that changes when the bass from the music hits
Jonathan Sikkema
on Jul 27, 2015 at 2:50:37 pm
Hello people off the internet :)
I want to make something but i dont know how...
I will post a video link so you know what i mean:
I can make the spectrum and everyting else accept that color changing on the music. Can someone help me with that?? :) I have adobe after effects CS6
Have a great day and thanks in advance.
Richard Herd
Re: Colour that changes when the bass from the music hits
on Jul 27, 2015 at 10:03:19 pm
That requires an expression from the math and design guru, Dan Ebberts.
By DAN EBBERTS
//change colors to the beat
threshold = 10.0;
colors = [[255,205,47,255]/255,[213,116,45,255]/255];
audioLev = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
above = false;
frame = Math.round(time / thisComp.frameDuration);
n = 0;
while (frame >= 0){
t = frame * thisComp.frameDuration;
if (above){
if (audioLev.valueAtTime(t) < threshold){
above = false;
}else if (audioLev.valueAtTime(t) >= threshold){
above = true;
n++;
frame--
colors[n%colors.length]
Jonathan Sikkema
on Jul 27, 2015 at 11:26:58 pm
Thanks for the reply!
I am trying to figure out how it works but till now i havent done that yet...
Can u say me what i need to do so i can get it to work??
Thanks in advance!
John Cuevas
on Jul 28, 2015 at 2:51:29 pm
Seems to be a line missing from the expression that Dan originally posted. To use this expression, you need to select your audio layer, go the "Animation" drop down > Keyframe Assistant > Convert Audio to Keyframes. That will drive your color changes.
Then add a fill to your spectrum, alt + click the color stopwatch and add this expression. In my example I have it set to 3 colors, RGB, you can add more colors by adding a ", [0,0,255,255]/255]" to the end of the expression, just make sure you take the last bracket ] off the previous color.
threshold =10.0;
colors = [[255,0,0,255]/255,[0,255,0,255]/255, [0,0,255,255]/255];
above = false;
n = 0;
while (frame >= 0){
if (above){
above = false;
above = true;
n++;
frame--
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
John Cuevas
on Jul 28, 2015 at 2:54:38 pm
Here's a simple project(minus the audio) that shows how you place the effect and expression.
9088_audiobeatexrpession.aep.zip
ThinkCK
