"Flop" a mask
Scott Witthaus
"Flop" a mask
on Jul 21, 2015 at 5:23:18 pm
Me again.
I am putting a couple interview clips in my composition. I needed to "flop" one and then created a mask to cut him out of the scene. Created the mask, but when I finished, the cutout went back to the "un-flopped" side rather than over my subject. Is there a way to make the mask "honor" the flop effect? Thanks in advance.
Scott
Richard Herd
Re: "Flop" a mask
on Jul 21, 2015 at 5:38:25 pm
Render order: SMET
Source
Mask
Effects
Transform
[Scott Witthaus] "Created the mask, but when I finished, the cutout went back to the "un-flopped" side rather than over my subject. Is there a way to make the mask "honor" the flop effect?"
The flop effect is 3rd in the stack, but Mask is second. It renders the mask first and then the flop effect (or lower if you used y value).
This is where PreComposing is important. It allows you to turn everything into a SOURCE, which means it's first in the render stack. Try precomposing your mask layer. And then apply the flop effect there, on the pre comp.
Scott Witthaus
Re: "Flop" a mask
on Jul 21, 2015 at 5:39:56 pm
(dope-slap to forehead)
That makes perfect sense. Thank you.
Scott Witthaus
Senior Editor/Post Production Supervisor
1708 Inc./Editorial
Professor, VCU Brandcenter
