"Can't be found" dialog will not dismiss // infinite loop situation
Eric Chard
on Jun 10, 2015 at 5:53:21 pm
Working on a project, moved a file w/AE open. AE throws up the "can't be found" warning, but PERSISTS in throwing up the warning despite repeated attempts to dismiss dialog. ("Yes, I get it, fine, let me WORK dammit!!!")
Seems like a bug: should be flagged ONCE and then ignored.
"Putting the HARM in 'harmonica' since 2005."
Dave LaRonde
Re: "Can't be found" dialog will not dismiss // infinite loop situation
on Jun 10, 2015 at 6:37:35 pm
Open the project with the caps lock key on. Delete the offending file. life gets better.
Dave LaRonde
Promotion Producer
Eric Chard
on Jun 10, 2015 at 11:29:46 pm
It's not like I'm opening the project, it's already open and running. I moved a file.
And while one might say "oh yeah: don't do that" (jk), it's still IMO a bug, because users shouldn't be required to hit OK a thousand or so times.
Dave LaRonde
on Jun 11, 2015 at 4:48:44 pm
Yeah, I get it. I'm just helping you get on with life in AE -- it's a workaround. And once you've worked around it, you can file a bug report with Adobe.
Dave LaRonde
Promotion Producer
