Animation vs Apple ProRes 4444?
Brenden Younan
on Jun 2, 2015 at 9:51:08 am
Hello,
For outputting alpha graphics, what codec is the best option? Animation or Apple ProRes 4444?
Thank you.
Dave LaRonde
Re: Animation vs Apple ProRes 4444?
on Jun 2, 2015 at 4:22:54 pm
It all depends on where it's going NEXT. If the next application can't read Prores 4444, it won't be very useful.
...but since we don't know where it's going next, we can't give you a straight answer.
Dave LaRonde
Promotion Producer
Stephen Smith
on Jun 2, 2015 at 4:27:28 pm
For me ProRes 4444 is less clunky then the Animation codec and I stopped using the Animation codec years ago.
Stephen Smith
Utah Video Productions
Check out my Vimeo page
Richard Herd
on Jun 2, 2015 at 6:54:20 pm
There are actual differences between graphics and video. Graphics are best in the animation codec, but video is best in APR codec (or some other video codec). In any case, the differences will be very small. It used to matter back when computers had to count not only fields but also interweave. And it matters even less now with Dynamic Link between Premiere and AE. Your final output is your final output.
In a quick nut shell: for green screen use APR4444, but for floating pictures, text use Animation.
But really Dynamic Link is awesome!
Brenden Younan
on Jun 3, 2015 at 1:21:24 am
Thank you all for the help guys.
I use AE then place lower thirds graphics with text into Adobe Premiere Pro for final delivery into encore DVD, PAL.
Dave LaRonde
on Jun 3, 2015 at 5:59:31 pm
If that actually means, "I use AE to make animated lower-third backgrounds", sure, why not use ProRes 4444? It ought to work just fine. Knock yourself out.
If you're actually adding the text in AE as well, I'd consider using Premiere Pro for the text. That way, you render an animated background once, and put any kind of text you want on it over and over again.
Dave LaRonde
Promotion Producer
Stephen Smith
on Jun 3, 2015 at 6:28:14 pm
You should check out this tutorial on Live Text templates in PPro:
https://helpx.adobe.com/after-effects/how-to/create-animated-text-titles.ht...
Stephen Smith
Brenden Younan
on Jun 6, 2015 at 2:20:17 am
Thank you once again guys for all the help.
