Keyframing the beginning and end of a mask?
Gabi Bucataru
on May 22, 2015 at 2:55:31 pm
Hi Gang!
So I need a mask on this layer only for a few frames somewhere in the middle but not anything before and after that region.
What's a good way to do this? I see that the none/add/substract dropdown option is not keyframable.
thanks!
gabi
John Cuevas
Re: Keyframing the beginning and end of a mask?
on May 22, 2015 at 4:37:14 pm
You could create a keyframe 1 frame before and one frame after your mask, where it is the size of screen.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Daniel Waldron
on May 22, 2015 at 9:00:10 pm
You could also split the layer immediately before and after where you want the mask so your masked layer is its own very short layer. Command+Shift+D (or its PC equivalent) will split it at the spot of the playhead.
