Write-on effect creates a mask instead of stroke...
Jenny Bunnel
on Mar 30, 2015 at 1:17:39 pm
I wonder if its possible to generate the write-on-effect on a ai-layer (imported in my ae-project)?
I have handwritten i word in ai and I now want it to grow as i line. I know this is possible on a text-layer, but when I start using the pen-tool for making the stroke-path (that I want to hide my ai-word) a MASK appears instead! What shall I do??
Jenny
John Cuevas
Re: Write-on effect creates a mask instead of stroke...
on Mar 30, 2015 at 5:11:50 pm
the pen tool creates masks in AE. If you want, you can create your mask, press "M" and then just set the mask mode to "none", then it will just be a path you can use to for your effect.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
