Internal rendering pipeline and Adjustment Layers
Navarro Parker
on Mar 17, 2015 at 4:10:15 am
Where do Adjustment Layers fit into the order of internal processing in AE?
And what about stacking Adjustment Layers? How are those processed? I have about 40 4K Adjustment Layers stacked into a comp and it's absolutely brought AE to its knees.
Dave LaRonde
Re: Internal rendering pipeline and Adjustment Layers
on Mar 17, 2015 at 5:47:53 pm
I bet you don't need so many adjustment layers. I bet you can apply a lot of the effects to the footage layers themselves.
When you consider that an adjustment layer affects EVERY layer below it in the timeline, you're probably forcing AE to do a lot of needless calculating.
Eliminate or at lease minimize the use of adjustment layers... life gets better.
Dave LaRonde
Promotion Producer
Richard Herd
on Mar 17, 2015 at 5:54:28 pm
That is correct. Adjustment Layers create a duplicate of the layers below them.
