3D spinning object not exporting as 3D in AE
Paul Ess
on Mar 6, 2015 at 10:47:32 am
I'm new to After Effects (CC) and am having an issue trying to export my logo animation. I have made a basic spinning 3D logo which looks fine in AE but when exported it just displays as a 'flat' object - not actually in 3D. Im not sure if I need to select a certain setting somewhere to make this export correctly?
Any help would be appreciated,
thanks
Paul
John Cuevas
Re: 3D spinning object not exporting as 3D in AE
on Mar 6, 2015 at 6:13:01 pm
What do you mean by "export" it. AE only renders final files to 2D video. It doesn't create a 3D file that you can import into StudioMax or Cinema4D for further refinement.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Paul Ess
on Mar 8, 2015 at 11:46:54 pm
Thanks John, I got it to work by sending it to the Render Queue and not the other way I had been trying,
thanks!
Paul
