Client wants 1440x1080, ProRes422 and I'm on a PC.
Edward Foster
on Mar 6, 2015 at 6:14:12 am
I bought a converter, but I know I'm not setting up my composition with the correct settings. I just can't figure out the right preset to make the initial AVI. I'm lost with a lot of this stuff.
Tero Ahlfors
Re: Client wants 1440x1080, ProRes422 and I'm on a PC.
on Mar 6, 2015 at 7:10:04 am
The resolution should be 1440x1080 and the pixel aspect should be HD anamorphic 1,33.
Edward Foster
on Mar 6, 2015 at 11:37:33 pm
Thanks. I see in the composition settings I see for Pixel Aspect Ratio are: HDTV1080/DVCPRO HD 720 (1.33) or Anamorphic 2:1(2). I assume the fist one is what I want since it's ratio is correct, even if it doesn't mention Anamorphic?
Dave LaRonde
on Mar 9, 2015 at 6:14:16 pm
NO! That's wrong! Make a custom comp using the settings Tero mentioned.
Dave LaRonde
Promotion Producer
