AE Lower Thirds Opacity and Alpha channel problem
Dave Brown
on Feb 12, 2015 at 2:48:23 am
Hello anyone,
I've purchased a couple lower third templates for After Effects for using in my live stream broadcast.
I've changed colors, added my logo, changed text etc. I can export in Pro-Res and the titles look great on the computer and in Premier. Problem is when i export them and stream them through the DSK function (luma key mode) on my Roland V-40HD i lose the varying degrees of opacity.. in fact everything is solid and the gradations of green seen in the example at 21:29 aren't there, they become gradations of grey.. also the red box behind the name of the Commissioner is supposed to be set to %60 opacity.
please check Port Commission Meeting lower third at 21:29
Also, notice the nasty jagged edges that show up.. they aren't there when i composite on my computer. I really need these transparencies to work live and to avoid these horrible edges i'm seeing.
Can anyone help me with this?
thanks
