Can you keep only black in footage and make everything else transparent?
joe marston
on Jan 29, 2015 at 3:18:19 pm
So i have this effect called unknoll, and it removes black from any footage. (obvious reasons why its useful) but i have footage that is a transition into black and i want to keep the black and remove the background footage. sooo i need everything to be transparent except black. i tried a few things, and got nowhere. does anyone know how to do this? is it possible?
John Cuevas
Re: Can you keep only black in footage and make everything else transparent?
on Jan 29, 2015 at 5:16:53 pm
Use a luma key, set it to key out brighter and set the threshold low, 16.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
