how to merge 2 colors to emerge a different color?
Manohar Stramzik
on Jan 28, 2015 at 2:48:04 pm
Hey folks an animation in my video requires 2 different colored solid which are round in shape and when they both merge together i want the color to emerge as a different color(not the one which gives when i change the layer style to add).
Can anybody please guide me how do i do that?
Thanks for at least reading my thread and it would mean a lot if you would guide me through this.
John Cuevas
Re: how to merge 2 colors to emerge a different color?
on Jan 28, 2015 at 5:54:11 pm
Duplicate your 2 solids and put them in a precomp. Create a solid with your final color. Place the precomp above the Final Color in the layer stack, then change the final color's track matte to "alpha matte"
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Chris Wright
on Feb 3, 2015 at 6:50:53 pm
did you want them to create a secondary color effect so that they blend into a mixed color only where they overlap, like gels? I only say this because then you can drive the true color with a linear blend instead of an alpha matte.
