How to stop new comps from opening up
Scott Hathaway
on Jan 10, 2015 at 1:32:40 am
Hey cows, this is an annoying enough problem for me to make a post asking for help. Every time I create a new comp from a clip or graphic in the project bin it automatically opens up as a new tab in my timeline and shows up in my viewer. This is annoying because most of the time all I want to do is make a new comp to drag directly into the current comp timeline, and not for it to open up. Is there any preferences button I'm missing so that it doesn't happen? Or should I change my workflow to add the new graphic to the timeline first and then precomp once it has been laid in?
John Cuevas
Re: How to stop new comps from opening up
on Jan 10, 2015 at 5:39:34 pm
What you are doing is essentially making a pre-comp. Drag the footage into your curent comp, select the layer and press "cntl+shift+c", and make sure 'open comp in new window' isn't checked.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
