Video after effects template causing newb problems :-(
David Honan
on Jan 8, 2015 at 5:38:38 pm
Hi from totally pitch black freezing York UK...
Hands up I'm a newb with limited after effects experience (but I have build comps before and followed lynda.com training) which will probably explain why I'm running into early trouble with a slideshow Ive just downloaded from video hive @ http://videohive.net/item/wedding-photos-slideshow/4565295
http://i216.photobucket.com/albums/cc53/zymurgy_bucket/drop-pic-template-af...
The above link illustrates my problem but here goes...
I want to drop my pictures into the frames but I just cant get it to fit the perspective of the frames. Is there a technique I could follow? I really hope each picture does not have to be individually re aligned that could cause me to hammer the coffee machine.
Well heres hoping someone takes sympathy on a newb who has wondered into the after effects jungle with no previous tours of duty experience ;-)
David
Daniel Waldron
Re: Video after effects template causing newb problems :-(
on Jan 9, 2015 at 6:06:43 pm
Unless your photos are the exact size as the frame compositions, you will likely have to adjust each one in the frame.
Or maybe you want a horizontal frame where a vertical one is? In that case, duplicate a horizontal frame in the project window and option+drag it too replace a vertical one in your timeline. You'll likely have to move it a little to get it looking right, but it should get you close.
Templates often need more adjustment than we anticipate. If only it were so easy. ;)
Daniel Waldron
on Jan 9, 2015 at 6:08:50 pm
Also, you are opening the photo comps, right? Don't replace them with a photo; double click it and add your photo in the precomposition.
David Honan
on Jan 13, 2015 at 4:51:49 pm
Thanks Daniel & here the final output :-)
