Working/Color Space and Linearization Editing with Scripting
Kerry Shawcross
on Jan 6, 2015 at 9:40:26 pm
Hey all, hope this is the right spot to post this-
For context: I'm making a setup automatization script for a team of compositors for an animated production. It grabs footage, layers it in the correct order, sets up the render queue, and saves it out. That works fine. My problem comes with some of the more project related settings.
I'm able to script changing the color depth to 32-bit, but I'm not able to find any methods/variables for color space (referred to as "working space" I believe) or toggling linearization. Has anyone else done this before or found out for sure that it's impossible?
Scripting using ExtendScript and JavaScript for AE 2014, using CS6 scripting guide because that's the most recent I could find. Thanks in advance!
-Kerry
John Cuevas
Re: Working/Color Space and Linearization Editing with Scripting
on Jan 7, 2015 at 12:43:09 pm
You might want to try the Expressions Forum, they have more experience with scripting.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Kerry Shawcross
on Jan 7, 2015 at 6:43:33 pm
Will do, thank you!
-Kerry
