I want to know what plugins used for this effect?
Ramana Kumar Ch
on Dec 16, 2014 at 6:32:19 am
Hi All,
Can some one help me to find this plugins.
Please see the video.
Ramana Kumar
John Cuevas
Re: I want to know what plugins used for this effect?
on Dec 16, 2014 at 2:07:30 pm
I didn't see anything that would require the use of third-party plugins. Most of the effects looked to be simple wipes, linear & radial(Transitions). The lines looked to be paths with a stroke(Generate) applied to them. Though if I were to do that I would probably use shape layers, little more control.
Is your 4th picture, are you talking about the blur? That looks to be a simple motion blur, you move a layer, turn on motion blur for that layer and turn on motion blur for the composition.
Also, it's helps a bit more to tell us the timecode of the effect from your video, since it's motion graphics, it's easier to see it in motion.
You might also find this informative, Getting started with After Effects (CS4, CS5, CS5.5, CS6, & CC), lots of great information, tutorials...a lot of it free.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
