Compositing mask path strokes?
Ross Ishikawa
on Dec 12, 2014 at 10:46:00 pm
I am trying to animate a ribbon. The ribbon is to be red with black edges. I can make this easily by compositing 2 strokes (a wide black under a slightly narrower red) on a single path in a shape layer.
However, I would like to make a mask path to do the same thing (so the ribbon can grow across the screen). Is there any way to composite strokes of a mask path?
Thank you
John Cuevas
Re: Compositing mask path strokes?
on Dec 14, 2014 at 3:21:44 pm
You could make a shape layer "grow" by adding a trim paths animator to your shape layer.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
